Greg Law Posted April 10, 2012 Share Posted April 10, 2012 I'm having a problem with the rounded corner effect in the material editor. I have never got it to work. I even tried a simple 1.0m box with a 20mm rounded corner. Nothing happened when I rendered it. I have looked at a few tuts and followed them. Still I can't get it to work. I'm using an up to date 2012 3dsmax design Can someone help me with this? I have to be missing something. I did this tut using my laptop install. It has an Nvidia Geforce Optimus 540m graphics card. 8gig ram I have a main setup using a quadro 4000 card. 24gig ram Link to comment Share on other sites More sharing options...
Justin Hunt Posted April 10, 2012 Share Posted April 10, 2012 20mm round corner is too big, 5mm or less is best. If you want 20mm then I'd suggest actually chamfering the edge. Rounded corners is also units dependent jhv Link to comment Share on other sites More sharing options...
Greg Law Posted April 11, 2012 Author Share Posted April 11, 2012 Thanks Justin. Can you tell me what units you are talking about and which ones I should use. I thought this might be the issue. Link to comment Share on other sites More sharing options...
Justin Hunt Posted April 11, 2012 Share Posted April 11, 2012 Your display units Link to comment Share on other sites More sharing options...
Greg Law Posted April 11, 2012 Author Share Posted April 11, 2012 I'm using 1m display units Link to comment Share on other sites More sharing options...
Justin Hunt Posted April 11, 2012 Share Posted April 11, 2012 so put in 0.005 for a 5mm round corner Link to comment Share on other sites More sharing options...
Greg Law Posted April 11, 2012 Author Share Posted April 11, 2012 Thankyou for your help Justin, I have found the problem. I had been changing the mapping to a bigger map size than real world. When I used the realworld it worked fine. So it must relate to real world size only. Make sense seen as it is a rendering process. Link to comment Share on other sites More sharing options...
Justin Hunt Posted April 11, 2012 Share Posted April 11, 2012 Doesn't sound right to me, to two are not related to each other. What happens if you you do a material override with a simple grey mat A&D with round corners? Link to comment Share on other sites More sharing options...
Greg Law Posted April 11, 2012 Author Share Posted April 11, 2012 You are right this time it worked with a bigger mapping. Not sure what the problem was then, but it is working so I'm happy. :-) Link to comment Share on other sites More sharing options...
