nagarajcompu Posted April 11, 2012 Share Posted April 11, 2012 hello friends i have some metirals for v-ray but i dont know how to add in library please help me i have these type of metirals please find the attachment Link to comment Share on other sites More sharing options...
Aiduss Posted April 17, 2012 Share Posted April 17, 2012 Hi! Open material editor by pressing "M" if you on 3ds max. Go to Material -> Get Material or just press "G" it will open Material/Map Browser window. On the left top corner near "Search by Name.... " press on the black triangle. Then choose Open material library ... and there you go! Just find a place where your mat file is. Hope this helps. Link to comment Share on other sites More sharing options...
Boris Horosavin Posted April 17, 2012 Share Posted April 17, 2012 This is a material from vraymaterials.de, therefore it is packed and you need to unzip it first in a separate folder. Then you follow procedure Juris suggested (open Material menu -type M - then Material-> Get material and then point to .mat file in the folder you unzipped). This material obviously has no textures attached to it so you don't need to worry about re-linking pics to material, that should be it. Link to comment Share on other sites More sharing options...
AubreyM Posted April 18, 2012 Share Posted April 18, 2012 Also make sure that where you unzip and add the file is where it is going to stay. If you add it to max and then move the .mat file Max won't like that at all. Link to comment Share on other sites More sharing options...
