Render passes and blending modes
branskyj
Hi all,
Is there a "written rule" as to how the separate render passes should be mixed (what blending modes) in say Photoshop? So far I have only found that the AO pass goes only with Multiply blend mode.
Or is it all "whatever works the best" method?
Thanks guys.
I would be careful with that tutorial in the sense that compositing is definitely not something you can base on a recipe that works the exact same on every image. I think if you follow "rules" like this exactly, you might overlook a lot of opportunities for bringing out different aspects of different images. For instance, the shot might be a dark room or it might be a huge glass space flooded with light. Compositing the two images the exact same way might not yield good results.
