Ardak Posted April 17, 2012 Share Posted April 17, 2012 Hello everyone, I would request help regarding issue about expressions. I own supremely low amount of knowledge about expressions, and I have gotten this far with the help of a friend. My problem is as following: I have Morpher-modifier in one object, with two objects in the Morpher-stack. The form which represents the starting form, and the form which represents the ending form. My goal would be to be able to drive the Morpher evolution by rotating a bone (at this point the bone is Bip01 R Finger). I have got into the Parameter Wiring window, and set the Biped finger bone rotation value to Bezier Float, as also is the Morpher in Bezier Float. I have given to understand that there is certain formula to guide the bone to drive the Morpher values, which should be something like this: 100/(the angle from which the bone begins rotation-the angle to where the bone ends rotation) And the resulting value of this formula should be placed to this formula (Z_Rotation-the angle from which the bone begins rotation)*1,33(result value placed from first calculation, for example) But frankly, I do not have any idea as to in what form the formula should be insterted into the parameter window? Thank you for help. Link to comment Share on other sites More sharing options...
