Plz! Cannot see sky preview in 3ds max!
keilam
Hi all, i'm just a newbie in maxwell! i have a problem when using maxwell 2.6.1 in 3ds max 2012! in general setting, i have already tick on Sky preview, but nothing i can see in viewport! background is just black, no sky, no color! is there anything i must setting in 3ds max when set up plug in?
Plz, plz, plz help me! thanks thanks thanks so much!
PS: sorry for my English.
I don't use maxwell but it generally goes like this:
1. Put your sky texture in the "Environment map" slot (Rendering menu->Environment, or just type 8 to open the menu).
2. With perspective view selected as active go to "Viewport background" (alt+b).
3. Under "Background source" option check "Use environment backround option"
4. Also check "Display backgroud" checkbox in the lower right part of menu.
I suppose this should work.
  • 3 months later...
Hey. Could you solve the problem? I started using 3dsmax plugin as well an couldn´t fix it. My sky appers black whatever I do. Active View (fire) works fine, but not the viewport.
@boris tried your way but didn´t work for me. maybe I made a mistake...
...so I got rid of the problem. You have to change the displaydriver to direct3d like on the attachment...
Edited by reneweicker
