maxwell render on maya 2012
dominiktezyk
Hello folks!
I am using Maxwell 2.0 with maya2012. I am trying to render a piece of metal. this metal is painted white, meaning, i am using a *.png file with no background where you only can see the white area, so I have "holes" in the plate - wich is intended. the reason is: I cant model 350,000 holes into that geometry - so I use a png file created by photoshop. but maxwell render igrnores the not existing background and replace the NON-BACKGROUND of my texture with simle BLACK. I cant control this via the transparency or anything. does anyone of you have an idea how i can manage the problem?
I want to make only the "painted" areas of the png file visible. like mental ray would do this.
thank you !
  • 4 weeks later...
It does this intentionally because the only way to get an accurate alpha map is to have a black background. If you turn on the alpha channel you can apply it in photoshop or you can save the render as a tif or png and it should apply the alpha for you.
See this for more info... http://support.nextlimit.com/display/maxwelldocs/Alpha+channel
-Brodie
