zoeb Posted April 28, 2012 Share Posted April 28, 2012 (edited) HI Guys! my interior scene is not lighting with any standart photometric and vray lights. its due to today :-(( i attached the dark scene Thanks for any Help Edited April 28, 2012 by zoeb Link to comment Share on other sites More sharing options...
Boris Horosavin Posted April 28, 2012 Share Posted April 28, 2012 (edited) Hi, Your pic is simply too dark and small to actually conclude anything. Where did you put your lights, what type are they and what are your Indirect Illumination settings? Above all - please tell me you are not using Vray Physical Camera. Apart from that, from what I can see I would conclude: a) light is too weak, turn up lights intensity b) seems that something is blocking light coming through the windows (if those are the windows)-check if you're using transparent Vray material for glass or erase glass surfaces completely. Edited April 28, 2012 by Horosavin Link to comment Share on other sites More sharing options...
zoeb Posted April 28, 2012 Author Share Posted April 28, 2012 (edited) well the setting is adaptive subdivixsion-mitchell-net, global switch off enviroment on 5 irridiance map(high)-light cache sub division 1000 vray sun ,vray lights for windows vray ies for the ceiling spotlights and vray physical camera. i used this setting for an other interior scen and its better just lights didnt light. i have a curtain in front of the window i set light inside its still the same :-(( also i tried delete all lights set again,turn off vray and set again both of them is the same Edited April 28, 2012 by zoeb Link to comment Share on other sites More sharing options...
Boris Horosavin Posted April 28, 2012 Share Posted April 28, 2012 hi zoe, first of all I still think you should leave Vray sun aside for interior, especially because Vray Physical Camera is not suitable for this purpose. For example, I used only simple Vray light for windows an Standard direct light for sun in this one and it worked well: [ATTACH=CONFIG]47515[/ATTACH] However, if you still decide to stick with Vray sun try checking if it is linked to corresponding Vray Sky Texture. This texture is needed to have sun light and you should put it in Environment slot. Also check what I told, if there is some object or nontransparent material blocking lights. Link to comment Share on other sites More sharing options...
zoeb Posted April 30, 2012 Author Share Posted April 30, 2012 Thank you very much! Link to comment Share on other sites More sharing options...
