Error message after 100% photon emission (error 361001)
blank...
Hello everyone
I'm using Max 2012, scene is quite large with over 70 sky portals. Lighting is daylight system (MR sun, physical sky... all defaults).
I fired 1 million photons, at 100% i get error message, here is what message window says:
JOB  0.3  progr:    99.9%    photon emission on PC-PC.3
JOB  0.4  progr:    99.9%    photon emission on PC-PC.4
JOB  0.3  progr:   100.0%    photon emission on PC-PC.3
RCGI 0.3  info : light #0 (mr Sky Portal067|Instance), globillum emission, emitted: 2737679, stored: 612297
RCGI 0.3  info :   globillum light #0: light photons        2737679
RCGI 0.3  info :   globillum light #0: spec. refl. photons     4463
RCGI 0.3  info :   globillum light #0: diff. refl. photons   788460
RCGI 0.3  info :   globillum light #0: spec. refr. photons        4
RCGI 0.3  info : light #1 (mr Sky Portal018|Instance), globillum emission, emitted: 183337, stored: 46369
RCGI 0.3  info :   globillum light #1: light photons         183337
RCGI 0.3  info :   globillum light #1: spec. refl. photons      755
RCGI 0.3  info :   globillum light #1: glos. refl. photons       54
RCGI 0.3  info :   globillum light #1: diff. refl. photons    54258
RCGI 0.3  info :   globillum light #1: spec. refr. photons     3218
RCGI 0.3  info : light #76 (mr Sky Portal072|Instance), globillum emission, emitted: 3953952, stored: 599589
RCGI 0.3  info :   globillum light #76: light photons        3953952
RCGI 0.3  info :   globillum light #76: spec. refl. photons     1772
RCGI 0.3  info :   globillum light #76: diff. refl. photons   945233
RCGI 0.3  info :   globillum light #76: spec. refr. photons        9
SCEN 0.3  info : Trying to flush 1693 megabytes.
JOB  0.3  info : Trying to flush 1693 megabytes.
MEM  0.1  info : Trying to flush 1693 megabytes.
DBN  0.1  info : Trying to flush 1693 megabytes.
DBN  0.1  info : Trying to flush 1674 megabytes.
DBN  0.1  info : Trying to flush 1660 megabytes.
DBN  0.1  info : Trying to flush 1638 megabytes.
DBN  0.1  info : Trying to flush 1622 megabytes.
DBN  0.1  info : Trying to flush 1618 megabytes.
DBN  0.1  info : Trying to flush 1489 megabytes.
MEM  0.1  progr: scene cache flushed asynchronously 1693 MB for module JOB, now: 2210 MB
RCGI 0.3  error  361001: photon emission shader returned miFALSE: aborting photon tracing
INFO: Too many error/warning messages! 100 messages were ignored. Use the message window log file option to view these messages.
RCGI 0.3  info : optimizing access to globillum photon map with 76021909 photons
RCGI 0.3  info : wrote photon maps to H:\_3DS MAX\Projekti\sceneassets\renderassets\PhotonMap.pmap
RCFG 0.3  progr: scheduling precomputing final gather jobs
RC   0.3  progr: rendering finished
RC   0.3  info : wallclock  0:00:00.79 for rendering
RC   0.3  info : allocated 67 MB, max resident 3904 MB
GAPM 0.3  info : triangle count (including retessellation) :     1494757
MEM  0.2  info : total memory: 4094 Mb
MEM  0.2  info : free memory : 2872 Mb
MEM  0.2  info : free memory : 2837 Mb
MSG  0.0  info : Total non-render time: 267.2609 s.
MSG  0.0  info : Total geometry translation time: 0.0000 s.
MSG  0.0  info : Total object data translation time: 0.0000 s.
MSG  0.0  info : Total number of entities translated: 786.
I also get a message window that it was aborted "due to insufficient memory".
However, 1.76 GB photon map is saved to disk. So what's the deal, can i use this saved photon map or not?
Thanks in advance!
With that many portals you may not need to shoot that many photons, can you post you photon settings
Disregard everything, i realized i'm talking nonsense. If it can't handle just photon generation, there is no way it will render anything once displacement and FG maps are also loaded.
500 000 photons it is.
You can always generate the Photons and FG without displacment then turn it ON for the final render.
That is how i was doing it, it was just a matter of too much photons (to big photon map for RAM) for my computer to handle. Once i reduced the number of photons problems went away.
