Roodogg Posted May 7, 2012 Share Posted May 7, 2012 Hi Guys... I have just downloaded the 'PerformanceTest 7.0' program from cpubenchmark.net and am comparing processors... When benchmarking a processor, it not only comes up with the general 'Mark' or score, it also shows many more measurements which vary wildly... Just wondering if anybody knew which, of the nine sub-categories are significant for V-Ray and 3ds Max rendering... I ask this because, comparing the four processors (see attached image - Dual Xeon E5440 / i7 980 / i7 2600k / and my computer; Core 2 Quad @ 2.33 Ghz).[ATTACH=CONFIG]47563[/ATTACH] You can see that the various test give fairly varying results. Am I right to assume that the tests are inaccurate as it shows for 'INTEGER MATH' that my old Core 2 Quad is faster than a 2600k! CPU- MARK CPU- INTEGER MATH CPU- FLOATING POINT CPU- FIND PRIME NUMBERS CPU- SSE CPU- COMPRESSION CPU- ENCRYPTION CPU- PHYSICS CPU- STRING SORTING I'm not sure if this is a valid point or not, but I thought it worth asking before purchasing new hardware. Thanks. Link to comment Share on other sites More sharing options...
Slinger Posted May 7, 2012 Share Posted May 7, 2012 Not necessarily an error. it may be way the algorithm is written to calculate 'Integer Math' I will download this program tonight and run it on my i7-970 that is OC'd to 4.2ghz and see what I come up with. Link to comment Share on other sites More sharing options...
Roodogg Posted May 7, 2012 Author Share Posted May 7, 2012 It's a bit misleading actually... As people are able to upload their own benchmarks, it actually comes up with wildly different stats for the same systems (Same spec - RAM / OS etc) which leads me to believe some are OC'd etc without it mentioning. I'm doing research today as I have a very tight budget for a fast rendering PC and I am finding that buying a reconditioned dual Xeon is much cheaper than a modern sandybridge based system, with almost the same raw processing ability. Link to comment Share on other sites More sharing options...
Slinger Posted May 7, 2012 Share Posted May 7, 2012 [ATTACH=CONFIG]47564[/ATTACH] Here are my results. Remember I am running an i7-970 @ 4.2ghz Link to comment Share on other sites More sharing options...
Roodogg Posted May 8, 2012 Author Share Posted May 8, 2012 Ooh. Nice and fast. Minus 10,000 from that and that's mine! The i7 3930k shows a base score of 18,000. That's without Oc'ing. Reckon that's my new PC!! Link to comment Share on other sites More sharing options...
