Maxwell Grass
eric nixon
Thanks, The grass geo is generated onto any object with a grass modifier tag, when you hit render.
Whats cool is that the grass blades dont intersect each other.. :)
This image used nearly a gig of ram for the grass geo, so ram usage could be an issue.
The sunlight-hdri slows it down, This render was over an hour on 12 real cores @3.8.. but I also cranked the settings right up (20 subdivs per blade), so that affected ram usage too.
If you need to cover a football pitch you can use much, much more optimal settings, and crucially theres a progressive LOD filter to reduce the number of distant grass blades.
Edited by eric nixon
