I'm having a problem with my Vray sky and glass material
Greg Law
I'm having a problem with my Vray sky being only white.
I'm using Vray sun and Vray phyical camera
I have a Quadro 4000 graphic card
Also I can't seem to get tranpanent glass. Even if I download the glass from The Vray material de site. It only seems to reflect.
I have carefully followed all the tuts etc.
I'm new at using vray.
I am using version Vary2 The last update before the 2013 one
Also 3dsmax 2012 design
Can anyone suggest what is wrong?
I used to have the same problem with glass not being transparent:
Apply a new material with the refraction set to pure white, set IOR to 1.0:
1)if the new material applied makes the glass transparent, then the problem obviously lies in the previous material.
2)if the new material gives you the same result, try placing a few objects behind the glass and render to check if it's really not transparent, or just your eyes playing tricks on you.
[ATTACH=CONFIG]47599[/ATTACH][ATTACH=CONFIG]47598[/ATTACH]Thanks again for the help.
Today I got transparency to work. Not sure what the problem was. I cleared the material maker and made a new Vray glass material like I did the other day and it worked straight away. I suppect it was picking up an issue from my other file through the material maker.
Now the other problem was solved as well. However it brought up a new issue. In my tuts they say turn off effect background when using HSV exponential or exponential. When I do this I get a white backgound with a black outline on my model. Like attached.
When I turn on effect background I get what I consider a normal background. Is this normal or have I got a setting wrong?
It also looks like a gamma thing from here. Try using LWF with linear color mapping or reinhard at a 0.7 burn. Are you actually using GI?
If the glass works now, don't forget to set its IOR back to 1.56 which is about the correct value for clear glass and fresnel turned on at about 2.0.
