wasteland giant Posted May 15, 2012 Share Posted May 15, 2012 (edited) display unit is set to mm system unit = 1cm attached pic explains it. measures wall @ 6344mm (approx) put dummy down. Move it up 6000mm and it over shoots. Can't seem to trouble shoot this. I'm sure its got something to do with system units. This is the first time I'm experiencing this. Please see attachment of what happens. * set up new file with same settings. And it works as it should. I am currently doing a full file merge back into this new file. Edited May 15, 2012 by wasteland giant Link to comment Share on other sites More sharing options...
Tommy L Posted May 15, 2012 Share Posted May 15, 2012 You may have a sticky key on your keyboard. Shift, control, space or something like that. Its happened to me before.... Link to comment Share on other sites More sharing options...
wasteland giant Posted May 15, 2012 Author Share Posted May 15, 2012 pretty sure that's not the case. testing: new file with SAME units (display + system). merge bits in. green cube was created in old file @ 6000mm and comes in at 1651mm red cube is 6000 mm in the new file.[ATTACH=CONFIG]47601[/ATTACH] Link to comment Share on other sites More sharing options...
wasteland giant Posted May 15, 2012 Author Share Posted May 15, 2012 had to merge everything into a new file. fixed the problem. was getting really annoyed too X_X' Link to comment Share on other sites More sharing options...
