Displacement problems
tiago
Normally for my renders I use a displacement map for doing the roof shingles, and it always worked perfectly in max design 2009 (vray renderer), but now with 2011 it looks like crap, bunch of extra waves and displacents that shouldn't be popping up. Using the same settings for both as far as I'm aware too. In 2011 it is especially hideous at greater distances. Is there some addition settings I need to be messing with to get it looking right?
Edited by tiago
  • 1 month later...
Not sure if people weren't replying because the attached images weren't showing or because no one knew how to fix it? I have uploaded external pictures so hopefully that fixes at least that problem (the attached ones were no longer showing for me).
I'm using the vray renderer too so I'm not sure if I should be posting this here or over in the vray section.
  • 3 weeks later...
A couple of reasons people probably didn't reply...
I suggest you upload the following (if you haven't figured it out yet):
1. Post Material
2. Explain whether you are using Mat Displace or VrayDisplacement map.
3. If it's the latter, post settings for that.
