muhamedthufail Posted May 17, 2012 Share Posted May 17, 2012 Hello everyone .... i recently bought a pc 16gb DDR3 AMD Phenom 1TB HDD 2x1GB ATI GPUs .. My problem is that no matter what i do .. None of my VRay scenes use enough RAM [ it seems so ] ... Some suggested to increase the poly count .. i did some tweaking in Vray System tab ... Memory allocation : Static But still its nt using more than 5GB ... What should i do ? ... is there any other settings ? n BTW ... i did disabled my Page File as well as i wanted my RAM to b utilized instead... Nothing seems to work ... Link to comment Share on other sites More sharing options...
off the cuffe Posted June 1, 2012 Share Posted June 1, 2012 From my understanding, Vray only takes what it needs.Loads the geometry using Ram,Loads the Maps,calculates the GI maps. you could trying increasing the BSP tree size.(set at 80 by default)this will let vray use more ram, but beware, sometimes it's not worth the trouble. Link to comment Share on other sites More sharing options...
