digibreakthe1st Posted September 16, 2004 Share Posted September 16, 2004 I have a intell pentium 500 mhz server with 4 500 megahertz xeon processor, its a quad processor machine. with 3 gig ram and a fx5200 pci card, 80 gig 10,000 rpm hardrives sci compatible. i would like to get the most out of until i recieve in the next month or so, my workstation from alien ware. what is the best drivers to maximize and to make it render faster if theres any tips or how to make this happen i would appreciated the help. i use 3d studio max 6.0 with service pack 1 and i would like to know if there any way i could make max use all four processors to render faster. Link to comment Share on other sites More sharing options...
vbrisebo Posted September 17, 2004 Share Posted September 17, 2004 Hi, On the render side of things, the driver really has no impact. It's all up to your processors... With 3dsmax 6 there are 2 ways you can optimize for 4 cpu's: 1 - Render using backburner (network rendering) with the "split Scan lines" option when using the Scan Line renderer. For more info on this start 3dsmax, go to Help > User reference > and in the search tab search for "strips". The first topic found should be "Strips Setup Dialog", this explains the procedure... 2 - Render using Mental Ray. 3dsmax 6 comes with a dual CPU local license so if you want to use all 4 cpu's you would have to purchase extra network licenses of Mental Ray. The graphics driver has an impact on the display speed in the application. The rule of thumb with nVidia cards is to always run the latest drivers... Read this document for help on optimal settings: Blatant Logic - Settings - Using D3D display mode in 3dsmax 6 Hope this helps... Link to comment Share on other sites More sharing options...
