scale I need help please
Cesar R
It's usually metric yes. As STRAT said. It doesn't have to designate metric or imperial.
The conversion would depend on what scale you need it to translate to. Best solution would be to see if there are any dimensions on the plan and work from that. My guess would be that dimensions on the plan would be either in millimeter or meter. In some cases I've seen drawings in centimeter, but it's rare.
those funny americans still use feet'n'inches
But I guess that they are at least consistent. We still have all our road signs in miles but for over thirty years, schools have been teaching us about kilometres. Then we buy spirits in metric but "beer" in pints!?!?
More troubling for me is 1:200 equating to a scale factor of 2400.
That would, in this country, mean 1" = 200'. It is called engineering scale, because it is generally a scale used by civil engineers, due to the large size of the projects. It could be 1" = 2400", but that requires too much conversion. No one wants to think in inches, if you are drawing a site that is 300’ wide. Hope that helps.
in Canada we use metric primarily, SO
scale 1:200 is 1mm = 200mm UNLESS stated on the drawing that the units are metres.
most countries (japan included) are metric.
if we're talking a house (we are) it's absurd to suggest that the scale would be 1"-200' think about it guys even 1"-200" is silly :D
Now you just have to figure out which metric scale it is, mm or cm.
1:200 is always going to be 1:200. i.e. 1mm=200mm or 1cm=200cm. We don't do 1mm=200cm as that would be 1:2000.
Even if the "units" are in metres it would still be 1:200. You just choose how you measure. If in doubt, get a scale ruler.
I need to reproduce a floor plan for an assigment at school, and the scale reads 1:200 what does that mean? used to imperial is that metric? and is there some sort of conversion so I can scale it and redraw it?
thanks,
ok Cesar, You have a plan drawn in 1:200 (metric) you're probably going to want to reproduce this at a 1/16"-1' imperial scale (16*12=192 approx 200) so it'll be on a similar sized drawing sheet.
(1" = 25.4mm , 1' = 304.8mm, 1m = 1000mm you get the idea...)
the drawing scale will most likely represent millimetres not metres (ie the dimensions will be 600 not .6 etc..)
