off the cuffe Posted June 2, 2012 Share Posted June 2, 2012 Hi Guys, I know there is alot of subjects regarding the "JPEG memory error", but i think is is not the standard.don't know if it's a network issue, or software. If I DR via backburner to calculate light cache pass on one machine using the render farm's CPU's, it seems to get a "JPEG Memory error" at the end of each frame ( once the pass has been calculated).not to sure if this error is caused because it can't save the IRR map fast enough back to the server or DR is cause this.Or backburner. If I render without DR to same computer, and IRR map gets saved to the same location.not a problem. I have done this method ( DR via backburner) all the time, but because this particular scene is quite large, I think my network might have something to do with it. Any Thoughts?.... Link to comment Share on other sites More sharing options...
