"upgrade from 3ds max to 3ds max design - plugins reinstall?
jensandersen
Hello
Currently i have 3ds max 2012 installed with alot of plugins and such, now i would like to try out the "extra" features in 3ds max 2012 Design. I would like to avoid having to reinstall plugins and re"setup" toolsbars all over. So how should i procede with this "upgrade"?
Is it just copy/paste certain folders or? Couldnt find anything on autodesk about it.
Thank you.
Kind regards
Jens
to my knowleage if the plugin are not made for the newer version they cannot be used with a a new version, so if you want to keep the plugs i would stick to the one your using jennifer
Jennifer?! :)
I currently have max 2012 installed and want to go to max Design 2012. So, same version, plugins work fine for both im sure. I just wanted to try the extra features of the Design edition. Im wondering if I can just run the .exe of the Design installer and it will upgrade my current installation with afflicting the plugins and such.
it's probably best to re-install the plugins but if you know what folders they are copied into you can usually just copy them over. to copy the prefs simply copy C:\Users\username\AppData\Local\Autodesk\3dsMax\2012 - 64bit\enu to C:\Users\shane\AppData\Local\Autodesk\3dsMaxDesign\2012 - 64bit\enu
the UI will look like it was in Max (default of dark) but the additional features for Exposure and Civil View will be there.
