BadboY Posted June 20, 2012 Share Posted June 20, 2012 Hi Guys, I am facing this problem. Plz evaluate n give some solution Link to comment Share on other sites More sharing options...
Nic H Posted June 20, 2012 Share Posted June 20, 2012 you need to do a realflow or water simulation to put the fire out..... failing that check for standard materials or materials with high diffuse values - is it imported geometry? looks like you have a red or yellow object in your scene that the sun is hitting on causing those irregular coloured artifacts Link to comment Share on other sites More sharing options...
Chris MacDonald Posted June 20, 2012 Share Posted June 20, 2012 you need to do a realflow or water simulation to put the fire out..... LOL. Only a 3D geek would get this. Link to comment Share on other sites More sharing options...
BadboY Posted June 20, 2012 Author Share Posted June 20, 2012 you need to do a realflow or water simulation to put the fire out..... LOL i dont think that will help.. had done copule of tweeks in the material n wating for the render keeping ma fingers crossed & yea there is a tree there.. will try removing it would be the last option i guess.. thanks for taking out time to reply i was helpful.. sply realflow part Link to comment Share on other sites More sharing options...
3vendhan Posted September 17, 2012 Share Posted September 17, 2012 look for any miss placed vray or Mr.planes on that area..... Link to comment Share on other sites More sharing options...
jackbird Posted September 17, 2012 Share Posted September 17, 2012 I have good results rendering a VRayDiffuseFilter pass, then applying it over my beauty render in Color mode. At 100%, it completely desaturates GI, but masked to the problem areas and/or applied at lower opacity it can be less heavy-handed. Link to comment Share on other sites More sharing options...
