Horrible Perspective 2012
odyzmil
Hi does anyone know why I get these disgusting perspective in 2012?
The attached image is in Shaded.Ive tried everything from Realistic,Consistent Colours,
shaded and edge faces,Hidden Lines but they are all the same.Is that a glitch or something?
Also check to see how far away from the origin your model is. If this came from a cad program, it may be miles away from the origin, in which case 3ds Max will exhibit precision errors like this. If you have access to the cad file, move everything to the origin in the cad software and re-save it.
Well, I don't know about Revit, but I have done lots of convertions from SketchUp to max with success. If they gave you a max or a 3ds file then probably they haven't done the convertion in the right way. They have to give you
It seems that something like a triangulation has happened for each polygon in the scene. It's really terrible what has happened!
Can you see all the polygons from their correct side? I mean are there any polygons flipped? Maybe that's why you can't see the facing polygons to your camera. But even if this has happened I wouldn't recommend you to flip all the wrong polygons. I had done it in the past and it was for the first and last time! :-0
Another solution I can think of is to keep all the good objects and try to model the distorted ones (good luck with that... :-) ).
Check from this link the first eleven pages. It explains how to convert from revit to dwg and then link it with max.
http://images.autodesk.com/adsk/files/workbook_imperial_032607_final.pdf
I think that Scott Dombrowski might also have a point. Check his solution too.
If the modeller do not know how to convert from revit to max then he/she then try as it is said in the pdf and see if it works.
I would like to know if you have any progress with the problem.
Hi Ody, the distance from the origin is a real problem, however, if your render is OK, and the problem is only in the viewport, you will probably fix it by
changing your graphic mode to OpenGl. It´s not the best graphic Mode, but in many cases fixes displays´s problems from CAD/SketchUp models.
I use Revit all the time with 3DS max and have never had this issue. It appears that all the normals are off. How was this imported into 3DS Max. As a .dwg or .fbx or .3ds? That would be good to know.
One thing about Revit. If you are exporting it out to .dwg you have to go into the options and change it from polymesh to ACIS solids for output. .fbx is great also and there should be no triangulation issues anymore with the current versions of Autodesk products.
I always have issues with Sketchup models in 3DS Max. But, I don't model in Sketchup and I'm sure it's more from the user's side than the software itself.
Adam
  • 2 weeks later...
What I am suggesting is not new, has been done above already; but after checking the
i) origin from 0,0,0 and then, ii) polygon normals, you may proceed as follows.
If you are importing it into max, be sure to check all the necessary ticks/options to bind objects by name, material, layer, etc. But if you are not importing but you get the model (max file) from outside, ask them to follow the standard procedure. This will certainly pull you out. Best luck, pal.
A problem I saw consistently when importing from Revit into Max2012 was conversion/scaling issues that caused the exact same problem.
Althout the models themselves were physicaly at the correct scale, if you select an object and have a look at its properties...what does it say?
I frequently had objects as an example: a 900x900x16000 column had dimensions in the properties as 0.03x0.03x0.4. If I applied a reset xform and converted back to edit poly again, the objects dimmesnions would show correct and the viewport issues would go away.
I think changing your system units to a bigger unit has the same effect as moving your model closer to the origin. Let's say your model is 1000 meters from the origin. If your system units are in meters, then from Max's point of view your model is 1000 units from the origin. However, if your system units are in centimeters, then from Max's point of view your model is 100000 units from the origin. I don't know at what size the precision errors start happening, but I think the good rule of thumb is to use large units for civil / site work, small units for interiors. Why not just use a large units all the time? I think the precision errors go both ways. If you're working with very very small objects and your units are in meters, you'll start running into precision errors again. At least, that's my understanding of it.
Dear Scott (and others, too),
As you may know, Max uses 1 inch as its default unit. So everything especially the light calculations and shadow blur/AA is done at that level. So if a trailer truck is only 5 cm. in length, it will give you way too big shadows and their blurs proportionately compared to a 5 meters long one. This is just one tiny fraction of the whole story; the lighting creates real big havoc and then the artist keeps on fiddling with many other (light) settings like size, intensity, color and so on to get the right look and feel at the expense of render times.
Edited by umeshraut
