Overide HDRI as an environment background
alfienoakes
Hey guys,
I thought I should be able to find the answer pretty quickly but I'm struggling. I have an animation I am setting up and Im using an HDRI as part of the lighting and all of the background. All ok, until I lift the camera up above the horizon and I see the bottom edge of the HDRI and a load of the base of the HDRI, ie houses, and the ground joining the sky.
I really want to keep this simple, so I want to use the HDRI as part of the lighting and then swap either a new simple gradient in, or the Vray sky. It needs to work in an animation basically.
Can anyone point me in the right direction, as I seem to have hit a bit of a blank.
Many thanks
Exactly, see if your dome has visability. Then either drop a new material in via the environment slot or map it to a half sphere and go from there. Or, just render against a black background and add in your background in post.
I think your easiest option will be to map a half sphere, that way you can easily control the mapping and orientation. That is if you don't choose to do it in post.
