big problem with 3dmax and vray 2012
yasharhtm
2.jpgAt first sorry cos of my bad english
I have installed max 2012 and vray 2.00.03,when i wanna use vray material vray material, vray material in material browser is without any texture and color and when i add it in material editor it is like this too,so i try to check texture for diffude and bump,the directiry is incurrect so i tried to do that manual i did it but when i add material on object,object showed just texture whithou any color and it is gray soooooooooo please help me i am fed up:(:(:(:(:(use real word map size is off
The images have some language that I do not understand, so can't say what you are trying to tell. But it is clear that the sample slot in material editor too does not show what you want on object :) meaning that material is not made properly, you need to check at that level itself. May be the bitmap folder (location) is not correctly configured in your 3Ds max user paths.
Edited by umeshraut
