No reflection using textures?
dsp_418
I'm moving my steps forward with Vray. I'm trying basic material setups, even though I've followed several tutorials, now I'm stuck with a very basic issue.
I've a Vray material applied to a plane. I've got a texture in the Diffuse channel and it works fine. Turning on the reflection and going from dark to bright, I would expect seeing the reflectivity increase. Instead the plane just become darker. The brighter I go on the reflect scale the darker the plane become (and I almost cannot see the texture anymore).
I must be missing some very basic knowledge here, but cannot figure out what.
I think Stephen is right. If you turn your reflection color all the way up to white (255) or full reflective then the only thing it can reflect is what is around it, which by default, is the black environment.
Try ticking Fresnel Reflections on. This should at least show you the material at blunt angles and become more reflective as your view becomes more glancing.
Fix Dark Glossy Edges is for a specific type of example. It is typically left off.
