Quicktime VR
JHalton
Hello,
Can anyone point me in the right direction of creating a Quicktime VR via Max6? We have been commisioned to preduce some food packaging but the client wants to be able to swivle around looking in at it. Could do with a Tutorial as I have never done it before. pooping.
Your nervously.!
Dan
I recently did a bit of investigating into this and found two solutions to work the best.
1. If you have vray render your scene with a spherical camera with the FOV override set to 360 degrees. Then render your image with a width twice as big as the height. Then use this app http://www.panoshow.com/panocube.htm to convert the image to a cubic QTVR
2. If you don't have vray then get the CubicVR script here: http://plugins.angstraum.at/ You choose a camera and then it renders out the six sides of the cube. To combine the into a QTVR use the GoCubic app that comes with the script.
Both work great, much better than the built in QTVR tools in max.
