braddewald Posted August 8, 2012 Share Posted August 8, 2012 The problem is very basic. When I set up a pure black material with fresnel reflections, I get a sudden "dropoff" of reflections when I'm using a low reflection value at some point along the curved object (the sample slot sphere in this case). Refl. Glossiness has no impact on the sudden "dropoff". I'm using a completely standard setup along with linear workflow. Any idea what this is? Link to comment Share on other sites More sharing options...
Corey Beaulieu Posted August 8, 2012 Share Posted August 8, 2012 I've had this same issue. I've figured out that if you reduce a ref value below 48 this happens. In a way it makes sense in that objects that have lower reflection values tend to have lower IOR values, but as a default I just leave it 1.6 and stay at a min. of 50 for my ref color. Use the glossiness to get rid of any additional unwanted reflections. I don't have max open right now, but I believe that I have also resolved this with a falloff map. I could be mistaken though. Link to comment Share on other sites More sharing options...
braddewald Posted August 8, 2012 Author Share Posted August 8, 2012 I tried replacing the fresnel checkbox with a falloff map set to fresnel in the reflection slot but it just looked identical (same problem). It just seems like I should be able to use a refl. value below 50. Is Chaos Group aware of the issue? Link to comment Share on other sites More sharing options...
Stephen Thomas Posted August 8, 2012 Share Posted August 8, 2012 Drop the cutoff value down to 0.001, it's under options. Link to comment Share on other sites More sharing options...
braddewald Posted August 8, 2012 Author Share Posted August 8, 2012 That worked! Thanks so much!! Link to comment Share on other sites More sharing options...
Stephen Thomas Posted August 9, 2012 Share Posted August 9, 2012 No problem I think the default value keeps render times lower in general, but in certain cases it needs to be lowered. Link to comment Share on other sites More sharing options...
