stayinwonderland Posted August 12, 2012 Share Posted August 12, 2012 I've seen a few people put various lense flares into their 3d work and it's basically billboard style flat geometry with (presumably) opacity mapped images. So, question 1: what are these and is there a standard place to buy them? Secondly, animation lense flares - would you tend to do any kind of sun flare in post? Example - 18 seconds into this: cheers Link to comment Share on other sites More sharing options...
Nic H Posted August 12, 2012 Share Posted August 12, 2012 They would almost certainly be done in post using aftereffects or fusion with some kind of plug in like sapphire or knoll lens factory then maybe a secondary spill glow using the sky alpha as a mask. its pretty straightforward stuff - looks like a bit of key-framing on the brightness to make it shimmer and some rotation on the rays. nice planting in this animation Link to comment Share on other sites More sharing options...
stayinwonderland Posted August 12, 2012 Author Share Posted August 12, 2012 Ah ok. Makes sense. But what about still renders like this: http://www.cgarchitect.com/2012/07/the-making-of-paracete - if you scroll down to how she did the car lights. Any ideas? Link to comment Share on other sites More sharing options...
Nic H Posted August 12, 2012 Share Posted August 12, 2012 yep she used billboards there - she says in the description. you could do it either way really. easier in an animation to put them in post for flexiblity as they arent 'fixed' as such. Link to comment Share on other sites More sharing options...
stayinwonderland Posted August 12, 2012 Author Share Posted August 12, 2012 yeah, was just wondering if there was a common place people get those still flares for use with billboards. I've seen someone else use them. Or maybe they're just generated via a photoshop plugin or something. Link to comment Share on other sites More sharing options...
Nic H Posted August 12, 2012 Share Posted August 12, 2012 yep try getting Knoll Lens Factory plugin in photoshop generate them on a black background then screen them over your image. Link to comment Share on other sites More sharing options...
stayinwonderland Posted August 12, 2012 Author Share Posted August 12, 2012 Cool, I'll look into that. Thanks Link to comment Share on other sites More sharing options...
Fooch Posted August 15, 2012 Share Posted August 15, 2012 I'm an AE guy unlike nic. Optical flares by video copilot. For say interior lights etc, you dont even need to keyframe it if you use a luma value for the location (really neat trick) For a pure photoshop method, i would google some lens flare brushes. Set them to color dodge and control the intensity by the fill not opacity. Link to comment Share on other sites More sharing options...
stayinwonderland Posted August 15, 2012 Author Share Posted August 15, 2012 Cool, thanks for the tips Link to comment Share on other sites More sharing options...
