duduchier Posted August 14, 2012 Share Posted August 14, 2012 (edited) Hi, I'm having huge difficulties with caustics... I'm using caustics with a high caustic subdivs amount : 40000 from one Target Dir light. I can see the caustic patterns appearing properly. After a while, the process ends leaving only many separate points. I want much more points. I though subdivs at 40000 was enough... When I increase the subdivs amount, for instance 50000, I get nothing at all. I also set "Max photon" to 0 and "Max density" to 0. Trying other values does not change much. I set "don't render final image". Do you have an idea how to increase the amount of points (photons?)? I'm using 3DSmax 2013 with Vray 2.3. Thanks for you precious help ! Edited August 14, 2012 by duduchier Link to comment Share on other sites More sharing options...
