gustav_gans Posted August 15, 2012 Share Posted August 15, 2012 Hi guys, I have a scene with hdri light (like the blog entry by peter guthrie) and now I wonder how to get a proper alpha within photoshop to change the background image. I've tried some render elements (background, matid,...) for the hdri-material but all render completely black. Could you please give some advice? Thanks, Klaus Link to comment Share on other sites More sharing options...
Nic H Posted August 15, 2012 Share Posted August 15, 2012 make the dome light invisible? render it on black and use the alpha to replace to your hearts delight. you could even put a rocketship in. Link to comment Share on other sites More sharing options...
gustav_gans Posted August 15, 2012 Author Share Posted August 15, 2012 @-- Thanks for your reply. Solves my problem perfectly! Just because I'm curious, isn't there a chance to get a decent result with the main render? Link to comment Share on other sites More sharing options...
Nic H Posted August 15, 2012 Share Posted August 15, 2012 well you can put in a plane or geometry with your desired background image at the back of the scene use a vray light mat with your texture and tick 'compensate camera exposure' to match it but make sure its not visible to reflect/refract/shadow/everything in object properties also make sure its not generating GI in vray properties - otherwise it will add a strange light to your scene. there are probably easier ways tho! Link to comment Share on other sites More sharing options...
gustav_gans Posted August 16, 2012 Author Share Posted August 16, 2012 I do think I am blind. Where can I turn the dome light invisible (tried object properties und hide) - then I just deletet the dome light and everything worked fine...? Link to comment Share on other sites More sharing options...
Nic H Posted August 16, 2012 Share Posted August 16, 2012 dome light rollout tick invisible much the same as you would for a vray plane light Link to comment Share on other sites More sharing options...
gustav_gans Posted August 16, 2012 Author Share Posted August 16, 2012 sorry about that - works fine!!! Link to comment Share on other sites More sharing options...
