Tommy L Posted September 21, 2004 Share Posted September 21, 2004 Hello dudes, Im rendering an interior with one sun (mr area spot) coming through a window. Error message 'no photons stored after emitting 1000000 photons' whilst rendering. I understand this means its getting no photons bounced back? The help said to put everything in a sphere. This doesnt seem to help. Can someone explain what the error means and how to fix it please? Cheers, Tom Link to comment Share on other sites More sharing options...
gdamaso88 Posted September 21, 2004 Share Posted September 21, 2004 in the indirect illumination menu for mr check "all object generate or receive caustics & gi" or select the geometry right click go to properties and under the mental ray tab check generate global illumination and receive global illumination Link to comment Share on other sites More sharing options...
pixelperfectg Posted September 21, 2004 Share Posted September 21, 2004 I would think it would be more practical to use a spot light or direct light for the sun, in place of a single omni. Just keep in mind that your blasting photons 360 degrees with an omni. However, a spot light or direct light will focus those photons only where needed, like into a window, etc. Allowing you to turn down the settings a bit and speed up the render. Jeff Link to comment Share on other sites More sharing options...
kicks Posted September 22, 2004 Share Posted September 22, 2004 Link to comment Share on other sites More sharing options...
Tommy L Posted September 22, 2004 Author Share Posted September 22, 2004 Is an mr area spot an omni? figured it aint but im a beginner with mr.... Solved the problem by lighting the scene again from scratch. Had imported some lights from another file. Does anyone have any general tips on internal animations using mr? We are having limited success because the final gather solution is r-calculated in each frame causing interference in the shady areas of the renders. I need to fihure something out soon so we can decide whether to buy the licences for the farm. Or is v-ray a better option? or even scanline with baked radiosity? Link to comment Share on other sites More sharing options...
pixelperfectg Posted September 22, 2004 Share Posted September 22, 2004 Oh geesh, my bad...I could've sworn that your first post mentioned using a MR omni. I'm terribly sorry for the added confusion! Jeff Link to comment Share on other sites More sharing options...
kicks Posted September 27, 2004 Share Posted September 27, 2004 Error message 'no photons stored after emitting 1000000 photons' whilst rendering. ciao Link to comment Share on other sites More sharing options...
jucaro Posted September 27, 2004 Share Posted September 27, 2004 as an added info, that error is also generated when the objects in your scene was not set to receive and generate GI. Link to comment Share on other sites More sharing options...
nisus Posted September 30, 2004 Share Posted September 30, 2004 Hi Tommy L, Does anyone have any general tips on internal animations using mr? We are having limited success because the final gather solution is r-calculated in each frame causing interference in the shady areas of the renders. I need to fihure something out soon so we can decide whether to buy the licences for the farm. Or is v-ray a better option? or even scanline with baked radiosity? You can try to render the FGmap on the forehand and load it for the final animation... I haven't tried it, but it might help solve your problem... MR 3.3 (available with max7) is supposed to have texture baking inside... ;-) rgds nisus Link to comment Share on other sites More sharing options...
