Jonathan Fantucchio Posted August 23, 2012 Share Posted August 23, 2012 My Boss never likes my backgrounds and I'm OK with that since he's happy with everything else. He wants the freedom to easily change them. I currently render my backgrounds as image plains so that doesn't work for him. Can I render the background image as maybe solid green and can he use the VRay background channel to composite his own image. Also can he do this even though the composition has 3 planes/layers of transparent glass. What is the best solution for me to render so backgrounds can be changed easily on the above image with proper refraction. Should I just put solid green in the environment background. I know this seems like a dumb question I just want to know whats the most efficient way do it. Link to comment Share on other sites More sharing options...
Jonathan Fantucchio Posted August 23, 2012 Author Share Posted August 23, 2012 I'm guessing I have to do something with the VRAY raw reflection/refraction and combine them with the background pass. Link to comment Share on other sites More sharing options...
Ismael Posted August 24, 2012 Share Posted August 24, 2012 (edited) Your technique as well as the one you need is described here: http://www.indigorenderer.com/documentation/manual/techniques/compositing-your-scene-environment Edited August 24, 2012 by Ismael edit typo Link to comment Share on other sites More sharing options...
Jonathan Fantucchio Posted August 24, 2012 Author Share Posted August 24, 2012 Thanks Ismael! The techniques in the tutorial were a perfect addition. Link to comment Share on other sites More sharing options...
xEndlessxUrbiax Posted August 24, 2012 Share Posted August 24, 2012 I usually render with the mr-physical sky and save the rendering as a .png. The png saves the background as a transparency so it doesn't show up at all. When you take this into photoshop, you can add whatever backgrounds you want there. Link to comment Share on other sites More sharing options...
hockley91 Posted August 30, 2012 Share Posted August 30, 2012 100% transparent backgrounds for still shots. Makes a HUGE difference in the quality and flexibility of the rendering. Link to comment Share on other sites More sharing options...
