heni30 Posted August 23, 2012 Share Posted August 23, 2012 Anyone know of a technique to put ies scallops on walls in Photoshop? You can render the pattern you want using white on black but what happens after that in photoshop? Thanks. Link to comment Share on other sites More sharing options...
Corey Beaulieu Posted August 23, 2012 Share Posted August 23, 2012 I would imagine that you then use the "Screen" or "Add (Linear Dodge)" blending mode to make the black disappear and the light shape stay. You can then pin a Hue/Saturation Adjustment layer to it for coloration or you can just play with the opacity to control the intensity. Or Both. Link to comment Share on other sites More sharing options...
Ernest Burden III Posted August 24, 2012 Share Posted August 24, 2012 That's a fantastic idea! There are a few IES viewer apps that render a preview. Oh, and use Screen mode, low opacity. Link to comment Share on other sites More sharing options...
Fooch Posted August 24, 2012 Share Posted August 24, 2012 black layer , set on colour dodge.. paint anything you like on it. control transperancy and light bleed via fill not opacity Link to comment Share on other sites More sharing options...
heni30 Posted August 24, 2012 Author Share Posted August 24, 2012 (edited) Here's a tutorial I found: http://psd.tutsplus.com/tutorials/tutorials-effects/how-to-create-a-realistic-ies-lighting-effect-in-photoshop/ Haven't had a chance to go over it in detail. One idea I had was to take the white scallop shape and use it only as a selection tool with the wand; then make a copy of that portion of your wall. So you would have a piece of your wall, say wood, in the shape of your ies pattern WITH color and texture of the wall - then play with that. Will give it a try. Edited August 24, 2012 by heni30 Link to comment Share on other sites More sharing options...
M V Posted March 13, 2013 Share Posted March 13, 2013 I have gone as far as rendering a few of my favorite ies files projecting on to a black blank wall and taking that render file and turning each into a brush in Photoshop. Takes 15 min and then saves you hours down the road! I bet you could even find a bunch of these already made on Devianart. Link to comment Share on other sites More sharing options...
bindunarayan Posted March 15, 2013 Share Posted March 15, 2013 One of the best ways of lighting all your scenes in an organic way is to use IES lights. In general, IES lights are most commonly utilized in case of indoor or interior architecture renders. Using fake IES lights on walls in Photoshop is a great idea indeed, and I really admire it. Link to comment Share on other sites More sharing options...
M V Posted April 11, 2013 Share Posted April 11, 2013 Here is a set of files that could easily be turned into PS brushes. http://www.sketchupartists.org/downloads/?did=27 Link to comment Share on other sites More sharing options...
