landrvr1 Posted August 24, 2012 Share Posted August 24, 2012 When you import something from AutoCAD into Max, the default line color is always a light gray. Anyone know if you can change this? I've looked around and can't find a thing. Link to comment Share on other sites More sharing options...
landrvr1 Posted August 29, 2012 Author Share Posted August 29, 2012 Er, no way to do this? Link to comment Share on other sites More sharing options...
Scott Schroeder Posted August 29, 2012 Share Posted August 29, 2012 Generally it obeys the line color coming in from AutoCAD. Unless you are tweaking something in the import settings or your AutoCAD people are very lazy and don't use line colors. Link to comment Share on other sites More sharing options...
hockley91 Posted August 30, 2012 Share Posted August 30, 2012 When you import something from AutoCAD into Max, the default line color is always a light gray. Anyone know if you can change this? I've looked around and can't find a thing. It is possible that your wireframe "display color" is set to "material color". I have never had that issue when importing. I have it all set to "object color" in the display panel Link to comment Share on other sites More sharing options...
