doujay888 Posted September 22, 2004 Share Posted September 22, 2004 It's my first time to use radiosity daylight in interior lighting using the IES SUN, however I've tried several test renders and input values yet still I can't exactly get the way I want it to be. I have attached my test render and input values as well, kindly pls. check wether I'm using the right values? If you notice the image, the shades and shadows are not refine and quite bumpy which looks like dirt to me. How can I get rid of this? Please help me, Im running out of time!!!!! densYO! Link to comment Share on other sites More sharing options...
kicks Posted September 22, 2004 Share Posted September 22, 2004 Link to comment Share on other sites More sharing options...
jysngltndz Posted September 22, 2004 Share Posted September 22, 2004 try unchecking your 2sided shadow, it will cost you time to render.. a little higher for your filtering value (@interactive tools) Link to comment Share on other sites More sharing options...
doujay888 Posted September 22, 2004 Author Share Posted September 22, 2004 Thanks guys, I was able to get rid of the bump! I know it's not yet so refined, I'm still trying to do some test. Im searching for the interactive tools to edit the filtering value? densYO! Link to comment Share on other sites More sharing options...
doujay888 Posted September 23, 2004 Author Share Posted September 23, 2004 anyway thanks again guys! Link to comment Share on other sites More sharing options...
Jason Matthews Posted September 23, 2004 Share Posted September 23, 2004 Reduce the bump map on the couch. Is that leather? If so, it needs specular highlights. Set refine iterations up to like 25 or so. Filtering should be no more than about 3. Change the intensity of the sun to about 80,000. Then adjust the brightness and contrast. Also, make sure exterior is not checked. I would also change the midtones to like .9 or so. The wood is too orangeish red from the sun. And it seems too reflective. Just my opinion. -Jason Link to comment Share on other sites More sharing options...
