D-Pix Posted September 6, 2012 Share Posted September 6, 2012 Hi All, I was hoping someone could give me some advice... I'm working on a series of 3 visuals at the moment that will need to be produced for a hoarding roughly 2.5m high. I have spoken with the printer and our graphics team they recommend rendering the image to 8500pix high, meaning the image will be 72dpi. I will be sending the renders out to a render farm, so not too concerned with render time however I don't want them to be crazy!! I'm using Mental ray and will likely add a few passes, such as ZDepth, Lighting, AO and a reflections pass. So already adding to render time. Should I set my Anti Alias to 1/16? or lower? Should I set my filter to Mitchell or will Triangle be sufficient (I usually use Mitchell for stills) Any other tips? Many thanks for any advice. Cheers, Adam Link to comment Share on other sites More sharing options...
Tommy L Posted September 6, 2012 Share Posted September 6, 2012 Im applying logic from Vray.....your passes should not affect the render time, only the writing time which is negligible. 8500 is not that huge. Link to comment Share on other sites More sharing options...
D-Pix Posted September 6, 2012 Author Share Posted September 6, 2012 Would you render larger, say 16000 pixels to achieve 150dpi at 2500mm? Link to comment Share on other sites More sharing options...
Tommy L Posted September 6, 2012 Share Posted September 6, 2012 oh no, thats not my point. Stick weith the printers recommendation. It all depends on how far away the image will be seen from when it comes to resolution. What I meant is that 8500 pixels is not a dimension to be scared of. Link to comment Share on other sites More sharing options...
D-Pix Posted September 6, 2012 Author Share Posted September 6, 2012 Ok, thanks for the advice. Might bump it up to 10,000 then just to give the graphic designers a bit of bleed on the image. Link to comment Share on other sites More sharing options...
