scostumatu Posted September 7, 2012 Share Posted September 7, 2012 Hi Was just wondering if there is plugin for randomizing textures? For example, if I modeled and textured plank of wood, then duplicated this wood multiple times , is there a plugin to randomize the uv coordinates instead manually doing it? Thx very much S Link to comment Share on other sites More sharing options...
Corey Beaulieu Posted September 7, 2012 Share Posted September 7, 2012 Check out the floor generator: http://www.ronenbekerman.com/using-floor-generator-script-by-bertrand-benoit/ or just the material by element modifier: http://designertoday.com/Tutorials/3ds.max/1692/MaterialByElement.Modifier.discreet.3ds.max.Tutorial.aspx With the material by element you would be able to change the UV's but you could use a color correct and the crop tool on the same bitmap many times over to generate a different tones of the same type of would. The cropping would simply vary which part of the map will show, kind of like moving the UV's. Link to comment Share on other sites More sharing options...
Ismael Posted September 7, 2012 Share Posted September 7, 2012 Try this: http://creativescratchpad.blogspot.com/2011/06/random-uvw-map-gizmo-shift.html#more Link to comment Share on other sites More sharing options...
matthewgriswold Posted September 7, 2012 Share Posted September 7, 2012 Saw this one on Evermotion earlier: http://www.cgrecord.net/2012/09/download-material-creator-and.html Link to comment Share on other sites More sharing options...
scostumatu Posted September 8, 2012 Author Share Posted September 8, 2012 awesome - thanks for the response guys!! love this place Link to comment Share on other sites More sharing options...
