Unrealistic renders
cwx
Thanks for your suggestion. It indeed got better. I had added in a few vray lights. However, my render time took from 5-10mins(before add in) to hours! How can I speed it up?
Edited by cwx
Now I have another problem. Some of my windows on the exterior turn black after rendering. Whereas when viewed in viewport, it's totally transparent! What is the cause of it?
Yep. Agreed. You seem to want to jump from zero to hero overnight and it doesn't work that way. I could tell you how to speed up your test renders but I don't want you to take it as a rule of thumb. Read instead (and watch videos) instead.
For starters, set you Irradiance Map preset to Low and set Hsph Subdivs. to 30 and Interp. Samples to 15. Set your Second render engine from Brute Force to Light cache, you can leave the defaults. This is only for test renders, for production you have to up the settings.
For brightness, I suggest you create a Vray Physical camera and start with the defaults, then you can tweak f-stop, shutter speed and ISO up and down and see what happens. Baby steps bro (or sis?) you can't rush these things. Urgent won't help your work. Trust me, I know.
These tips are only a bare scratch of what you can do about it, not even close to a workflow, bare this in mind.
Good luck :)
