jccloutier Posted September 17, 2012 Share Posted September 17, 2012 i have an object being loaded xreferencely, and can be seen in wireframe in VP but doesn't show up in smooth and highlights and doesn't render out. no likey. Link to comment Share on other sites More sharing options...
Nic H Posted September 17, 2012 Share Posted September 17, 2012 sounds bad Link to comment Share on other sites More sharing options...
salvador Posted September 17, 2012 Share Posted September 17, 2012 Check your X-Ref control panel (Max logo - References - X-ref scene) and make sure your X-Ref is updated and nothing is checked in the Ignore field. Also, make sure it's enabled and visible. If that doesn't work, open your X-Ref scene and makes sure your objects are not "Invisible to camera" (Max Object Properties). If still it doesn't work, try and X-Ref your scene in a brand new file all at defaults. Hope it helps. Link to comment Share on other sites More sharing options...
