3dvizual Posted September 23, 2012 Share Posted September 23, 2012 Hi. My carpet with "hair and fur" not showing up in render. What can be the problem.? I have assigned the "hair and fur" under effects. Link to comment Share on other sites More sharing options...
salvador Posted September 24, 2012 Share Posted September 24, 2012 Same here. First time I try it. Link to comment Share on other sites More sharing options...
M V Posted September 28, 2012 Share Posted September 28, 2012 If you are using the VRay Frame Buffer you have to make sure Hair and Fur is set to MR Prim setting. Link to comment Share on other sites More sharing options...
salvador Posted September 28, 2012 Share Posted September 28, 2012 valerostudio said: If you are using the VRay Frame Buffer you have to make sure Hair and Fur is set to MR Prim setting. Thanks, I'll try. Link to comment Share on other sites More sharing options...
3dvizual Posted September 30, 2012 Author Share Posted September 30, 2012 Sorry, but where do I set the "hair and fur" MR prim settings.??? Link to comment Share on other sites More sharing options...
3dvizual Posted September 30, 2012 Author Share Posted September 30, 2012 I found it. Link to comment Share on other sites More sharing options...
