3dfabrique Posted September 27, 2012 Share Posted September 27, 2012 Hello all does anyone have an answer for the following I want to create a new partition on my hard disk to install windows 7 64bit (I've just done a fresh install of windows 7 32bit). Having never done this before, I was wondering 1. will my .max files created in 32 bit be compatible with 64 bit and vice versa. 2. Will I be able to read from the 32 bit partition when running 64 bit windows, or will I have to have a double copy of my files on the new partition ? 3. what size to make the new partition ? thanks Link to comment Share on other sites More sharing options...
Stephen Thomas Posted September 27, 2012 Share Posted September 27, 2012 Is there a reason you need both? If your system is 64-bit why would you want to run 32-bit Windows? Link to comment Share on other sites More sharing options...
John Dollus Posted September 27, 2012 Share Posted September 27, 2012 yes to numbers 1 and 2. 3 is rather up to you. I, like Stephen, think something you're doing is amiss When 32 bit apps install just as well with a 64 bit OS -poetry by john Link to comment Share on other sites More sharing options...
Umesh Raut Posted September 27, 2012 Share Posted September 27, 2012 In simpler terms, 32 bit has one bottleneck, if you will, or limitation of 16GB memory maximum. And moreover, the modern 64 bit processor architecture is way much more efficient than 32bit (older) chips in many computing tasks including heavy number crunching like rendering; that's where the newer OS versions exploit it to users' benefits. Its always better to have and use x64, hence. Link to comment Share on other sites More sharing options...
Stephen Thomas Posted September 27, 2012 Share Posted September 27, 2012 16GB? I think you mean 4GB RAM limit. Link to comment Share on other sites More sharing options...
3dfabrique Posted September 27, 2012 Author Share Posted September 27, 2012 thanks for the replies I've been using 32 bit for years. However I am now getting more ambitious with the complexity of some of my scenes. I'm therefore thinking of investing in a 64 bit capable software. (Stephan - I did try installing my 32 bit software on the 64 bit OS at first, but had problems getting all plugins to work - so I went back to 32 bit) So in theory, the new partition just needs to be the size required for the 64 bit windows software ? cheers Link to comment Share on other sites More sharing options...
Stephen Thomas Posted September 27, 2012 Share Posted September 27, 2012 Ah, see that's the mistake. You can install 64-bit and 32-bit version of max on a 64-bit OS at the same time, no need for two partitions! Link to comment Share on other sites More sharing options...
Dimitris Tolios Posted September 28, 2012 Share Posted September 28, 2012 The 32 and 64bit versions of Max produce identical files. There should be no issue sharing between the 2 platforms. The only real limitation of 32bit versions is RAM utilization: due to Win kernel limitations, only 3.2GBs (not even 4) can be addressed by a single app (and that's with a registry mod tbh). Most apps won't even try to address more than 2GBs in 32bit windows. Link to comment Share on other sites More sharing options...
