jonel Posted December 4, 2012 Share Posted December 4, 2012 I'm not claiming, I'm telling. i7 is great for a workstation, i5 i better for a render node - at least that was the case with previous generations, i7 and i5 (2700k and 2500k? not sure, I'm a bit outdated with latest HW). It does render a bit slowly but it's cheaper and less power and memory hungry. I'll post a screen with the same OS/max/vray and the same scene loaded. Got me too with a suprise when I saw it.. With 2000€ you should be able to buy a workstation + render node. If you don't buy monitors, you should be able to squeeze two nodes. Link to comment Share on other sites More sharing options...
jonasthomas Posted December 5, 2012 Author Share Posted December 5, 2012 Thanks fot the advice Dimitris! It is much appreciated. I will consider doing this. Link to comment Share on other sites More sharing options...
jonel Posted December 5, 2012 Share Posted December 5, 2012 Well... I've just tried - and it's not double, sorry. i7 does use more - but not double. As I've loaded some masterplan scene: i5 peak=6.67GB, and 5.54GB while rendering, 55min48s i7 peak=7.43GB, and 6.23GB while rendering, 50min45s Link to comment Share on other sites More sharing options...
