gav Posted September 23, 2004 Share Posted September 23, 2004 hey, just recieved some sections from are structural engineers, they look fine in 2d but the z references for individual points are all over the show. do you know of any way we can flatten the image so that the entire dwg has the same z reference? any help would be cool thanks gav p.s an under paid and under appreciated achitectural technologist seeks work! Link to comment Share on other sites More sharing options...
argie_uk Posted September 23, 2004 Share Posted September 23, 2004 Hi Gav, This is a lisp routine I did for the same reason, it was for AEC which used to have different Z values for different levels. It should work for basic elements, lines arcs, etc but no guarantees. Give it a go. Just copy the following text into notepad and save as a .lsp file. Run using APLOAD, and "zero" is the command name. WHen it asks for level of selected entities just reply 0. Richard (defun c:zero() (setq c (ssget)) (setq lev (getint "\nEnter Level of Selected Entities: ")) (setq levcount 0) (setq levdim 0) (repeat 11 (if (= lev levcount) (setq my levdim)) (setq levcount (1+ levcount)) (setq levdim (+ levdim 2600)) ) (setq d (sslength c)) (setq no 0) (while ( (zero) ;(setq perc (* (/ no d) 100)) ;(princ perc) (setq no (1+ no)) ) (princ) ) (defun zero() (setq ent (ssname c no)) (setq e (entget ent)) (setq ct 10) (setq upper 12) (if (= (cdr (assoc 0 e)) "DIMENSION") (setq upper 17)) (if (= (cdr (assoc 0 e)) "3DFACE") (setq upper 14)) (while ( (setq x (assoc ct e)) (setq x1 (list ct (cadr x) (caddr x) my)) (setq e1 (subst x1 x e)) (entmod e1) (setq e e1) (setq ct (1+ ct)) ) ) Link to comment Share on other sites More sharing options...
Onslaught Posted September 23, 2004 Share Posted September 23, 2004 See this thread... http://www.cgarchitect.com/vb/showthread.php?t=6809 or this.... http://www.cgarchitect.com/vb/showthread.php?t=5421 Link to comment Share on other sites More sharing options...
gav Posted October 6, 2004 Author Share Posted October 6, 2004 cheers guys on the same note- jokes about engineers! Two engineering students were walking across campus when one said, "Where did you get such a great bike?" The second engineer replied, "Well, I was walking along yesterday minding my own business when a beautiful woman rode up on this bike. She threw the bike to the ground, took off all her clothes and said, "Take what you want." "The second engineer nodded approvingly, 'Good choice; the clothes probably wouldn't have fit." To the optimist, the glass is half full. To the pessimist, the glass is half empty. To the engineer, the glass is twice as big as it needs to be. "Normal people...believe that if it ain't broke, don't fix it. Engineers believe that if it ain't broke, it doesn't have enough features yet." Link to comment Share on other sites More sharing options...
