Need an affordable render farm
stayinwonderland
  • 4 weeks later...
  • 4 weeks later...
Sorry to bring this topic up, but I'm going through the same situation as the OP right now. My options currently, are either Fox Render, or Rebusfarm. I just signed up for both of their trials about an hour ago, so I'll definitely give them both a chance.
However, how much would it approximately cost to get my own little render farm? I'm talking about 8-10 render nodes, nothing too fancy. Apparently I've been told that I won't even need GPU's in the nodes, just CPU's and cooling systems will do. Is this true, and if it is, is it feasible?
I ask because even though render farms like Fox seem like the way to go once you have finalized lighting and materials, but during the lighting process we tend to render a lot of single frames to check quality, which takes up quite a while, and I think having my own render farm will make the process more efficient.
What do you guys think?
  • 1 year later...
Hi,
Why not just build one for your self as I did? This is a much cheaper option.
There are a couple of company who sell render farm cases or small render farms.
I bought mine from here: http://3drenderfarm.com
They are selling cases and finished configs with 6 nodes. It worked out (depending on config) about £3-4000 for 6x i7 4770 nodes. It is quiet and working 24/7 like dream.:D
Good website with a lot of information.
  • 4 weeks later...
hi,
why not just build one for your self as i did? This is a much cheaper option.
they are selling cases and finished configs with 6 nodes. It worked out (depending on config) about £3-4000 for 6x i7 4770 nodes. It is quiet and working 24/7 like dream.:D
good website with a lot of information.
great info!
from 3drenderfarm.com:
"If you overclock your CPU ... the life expectancy will be very short, especially on continuous operation, so the short-term benefit is not worth it."
LOL :D ...what is "very short"? Only 10 years instead of 20?
and ~6000€ for 6x 4770 non K with only 16GB and without OS? Really? Is this incl. or excl. VAT?
The parts for one 4770 excl. the case are around 475€ w/o VAT ...x6 = 2850€
OK... it is cheaper than BOXX, but also without installation and for less than 6K € you can build 5 4930K with 32GB.
And a 4970K (4GHz) incl. 32GB RAM, ASRock Z97 Pro4, Thermalright True Spirit, 620W PSU, 120GB Samsung EVO, Case and Win 7 Pro x64 will cost ~820€
but nice Helmer Reloaded...
I was in very complicated moment with some project, and i found this:
http://www.render4you.de/start.html
This Guy (owner of http://www.render4you) helped me in every moment in my project. He spend over 6 hours at SKype to help me finish my 1200 frames animation. If some frames was lost because i made some mistake, he send me lost frames by Skype. He is real professional and cheap. I used C4D, 3D Max works too. On my 12 cores machine animation should take 280 hours - with render4you farm, animation was rendered in 8 hours :) It really works :) And user interface is soooo nice!
Greetings
http://www.3drenderfarm.com/store/p5/PERFORMANCE_MODULAR_CREATION_RENDER_FARM.html
This doesn't look bad to be to be honest, the price reflects the fact it's all ready to go, and very nicely made.
I have 1 render node, very similar CPU as above, and that was around £600 (inc Windows though)
http://www.deanpunchard.co.uk/mini-itx-render-node-build/
I would always favour a local farm over external, but I guess it depends how much rendering you're doing. Also I find the time involved in uploading and preparing files for renderfarms can be a lot, and not to mention if there are amends or mistakes to take care of later.
Another option could be to look at cloud rendering, using Amazon EC2? I have no experience of this, but a friend of mine uses it for rendering. All you do is setup a virtual PC, and then just pay for it when you need it.
Dean
I undertook this, http://www.helmer-air.com/ and it's actually pretty simple. I'd never built a computer before or even tinkered with electronics, so if I can do it then anyone can. The hardest part was cutting the holes in the cabinet.
Here's what it looks like - http://forum.vrayforc4d.com/threads/render-nodes-performance-cost-considerations.15250/page-2#post-114995 . It's now up to 5 nodes (or 'drawers' as I like to call them). I just buy more when I need them/have spare cash.
It all works fine, just switch on and hit DR on vray.
Each node costs about NZ$900/GBP450.
  • 5 months later...
Hi,
Occasionally I just need one frame rendering that would normally take 12-24 hours but so far, ALL the render farms I've seen would cost the entire project budget just to render one or maybe two stills!
Any tips on where to look?
I have this same question (note it's a couple or three years after the original post).
Any recommendations from users (not from render farm owners please)?
  • 2 weeks later...
  • 1 month later...
  • 4 weeks later...
