URGENT: help me vray proxy tree.plant jittering how to avoid
thiyagu
Help me friends,
Am working for 3dvisualizer,software using 3dsmax2012 plugins vray2.0,i am doing walk through for Architectural animation purpose.i am rendering Exterior street shot with car moment after finish my animation lot problem is there(proxy tree,plant,plant reflection part white small dot,stone texture wall using bump map noise came out,car moment with road block patch comes)how to avoid. i am attached my setting file Please Reply for this.
Edited by thiyagu
Hi,
There are a few things you need to do.
Firstly for the white dots try ticking the sub pixel mapping checkbox in the colour mapping rollout and re rendering a region to test it.
for the other problems i have a question. Do you have moving camera AND objects? Or just a moving camera?
No problem. Did that fix the white dots?
What version of Vray are you using?
If you have a moving camera and objects then the only way to achieve great results is to do the following setup http://www.workshop.mintviz.com/tutorials/flicker-free-animation-using-vray/
One last question (i think) do you just have one machine? Or do you have access to a render farm?
