VRay material not applying to object
Shaan
well i have made a VrayMtl using same bump and Diffuse map ... It is shown in the ball that u can see in the right hand side but is not shown in the elevational features.. which are rather giving a dark brownish shade whereas i have used same material on them ... same is the case with the roof ... I have used slate map for it but its not showing either. Moreover its extruded object as most of the objects in scene are ... basic spline work was done in Autocad ... JS
Edited by Shaan
the sphere is just a check i did to see if maps were loading.. which they were
But the problem is im not getting those maps on elevations features(dark brown in image)... I have applied same material as sphere on them but its neither showing in viewport nor rendering as well sir
Edited by Shaan
i havent added UV mapping ... and yes i will email u the file if u can please PM me ur email id
its done .. havent added UV map now as i did the problem is solved ... THANKS 4VIZ u really helped in time ... :) really needed a quick help in that thing
P.S. Thanks CGarchitect and members :)
Edited by Shaan
