abhishekmittal Posted October 16, 2012 Share Posted October 16, 2012 (edited) hello Frnds, i'm just starting learn vray lighting on 3ds max 2010 and i used vray adv 1.50.SP3a and the problem is my render is black. Render setup setting, vray Physical camera setting and vray light setting i have checked more time but render is black. so plz help me.. reply Edited October 17, 2012 by abhishekmittal Link to comment Share on other sites More sharing options...
Corey Beaulieu Posted October 16, 2012 Share Posted October 16, 2012 Can you screen capture your camera, lights, and render settings as well as the viewports? It could be anything from your camera being inside a wall to the exposure settings on your camera. Could also be lights and render setup. Its a vague question without more info. Link to comment Share on other sites More sharing options...
cg_Butler Posted October 17, 2012 Share Posted October 17, 2012 If you have any glass and translucent materials make sure Affect shadows is ticked. Then the light will come in to the room. Link to comment Share on other sites More sharing options...
salvador Posted October 17, 2012 Share Posted October 17, 2012 Also, if you used fog color for the glass shader, and the value is too high, no light passes through. Link to comment Share on other sites More sharing options...
Corey Beaulieu Posted October 17, 2012 Share Posted October 17, 2012 I'm having trouble seeing the settings clearly, but it looks like the camera may be set up wrong. Turn off Vignetting for one. This will darken the render significantly. Also, the F-Stop for interior is usually around 5.6 as a rule of thumb. Otherwise, the glass comments are likely the answer. Link to comment Share on other sites More sharing options...
ericchan Posted November 6, 2012 Share Posted November 6, 2012 Just another stupid opinion but it might be this coz I've experienced once before. Try to move your camera away from the wall for a little bit more. Max viewport have a tendency to show the view when the camera's barely touching/a bit inside of the wall, but will end up rendering pitch black. Or else same opinion as above Link to comment Share on other sites More sharing options...
