Exr
Captain Mal
I am trying to save an .exr from Max. It is not displaying as a choice in the VRAY frame buffer save as dialog. Anyone have any ideas why? Do I need to install the OpenEXR Plugin? I thought that was only for photoshop...
3DS MAX 2012 x64
VRAY 1.50 SP6
Any help would be appreciated!
Thanks, Brian.
That 'kind of' works. It does give me an .exr that I can open in photoshop... but it is not a layered .exr with all of the different passes collected in one comp. Is this a limitation of Vray 1.5? Odd thing is, the file balloons in size - so it seems that the layers are really there... but I cannot get PSD to open with all the layers.
That's only if you're writting your EXR our through the save image file option. When you're using the output to vrimg slot set to EXR like Marty is all channels get included.
It sounds like you're getting your channels embedded properly if your file is getting larger. Make sure you have the ProEXR.8Bi file in...
C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Plug-ins
and make sure if you've got it in the 64bit version of PS programs files that you are running the 64bit version of PS (or 32bit if you're behind the times)
Is there a specific reason you are writing our through the vrimg output slot? best option is use the max buffer write out to exr and put it on auto or select the g-buffers to include (can't use the vray buffer to get all the channels packed in an exr) then you'll know you've got that variable out of your problem.
(also knock it down to a 16bit float save yourself some file space / decrease load times when running exr sequences with embedded channels through aftereffects for compositing your animations)
Edited by BrianKitts
  shaunph78 said:
....add this to the list of why we need to upgrade to CS6.
oops sorry just double checked this so I didn't lead anyone astray..... CS6 supports OpenEXR files, but not layered EXRs, still going to need the plugin.
http://fnordware.blogspot.com/2012/04/proexr-ez-is-free.html
you should have CS6 though..... 4 words, adaptive wide angle correction!
