Selection Mode Settings
Michael J. Brown
I just switched over to 3dsMax 2012 (from 2011) and noticed that I can no longer exit from my (edit poly) selection mode by just hitting a number key a second time.
You know how you can just select an object that has the edit Poly modifier applied to it, then just type 1,2,3,4 or 5 to go straight into the vertice, edge, border, polygon or element selection mode? Well I'm used to being able to just hit the number key a second time to exit from selection mode alltogether.
That toggle no longer works. I've gotta go and click on the selection button to de-toggle it.
I'm assuming there is perhaps a line in some .ini file somewhere that just needs to be switched from 0 to 1 or vice-versa that will turn this toggle back on.
Does anyone know what to switch to regain this functionality?
Thanks
