Chris MacDonald Posted October 31, 2012 Share Posted October 31, 2012 Time lapse sky shot. I have a building and I'd like to put a time lapse sky in (above/behind it) to create an animation, but have the sky also picked up in reflections of both the glass AND the water in the foreground of the shot. I'm in two minds whether to do it in max, or do it in post. How would you guys go about it? Link to comment Share on other sites More sharing options...
John Dollus Posted October 31, 2012 Share Posted October 31, 2012 do it in post. render a mask for the glass and use the same timelapse as the background but offset the sequence and adjust for perspective. Same for the water. clouds are random enough that nobody will pick up on it being the same background if you offset the time between the elements Link to comment Share on other sites More sharing options...
Tommy L Posted October 31, 2012 Share Posted October 31, 2012 Are you shooting the timelapse your self? If so, get a towards and away shot of each frame. Two cameras would be best. Then put them on cards in Max, VRaylight mat (if youre using Vray). Will give best results. If youre using a purchased one, I'd do it the same but it depends what the angle of your glass is. Post a render, its easier to judge. Link to comment Share on other sites More sharing options...
Chris MacDonald Posted November 7, 2012 Author Share Posted November 7, 2012 Did it in post, it looked just as I wanted it to. Cheers guys. Link to comment Share on other sites More sharing options...
