Shadow through glass - Refraction
Andrew1
Hey guys,
I am working on a project - an interior sign,
I got a clear acrylic backer ( box ) at 3/4" thickness with cutout letters over the backer
I am showing the sign on the interior flipped box imitating the walls etc...
I got a couple of vray lights set up , my box material has vray mat with 100% refraction enabled diffuse white etc a glass imitation sort of...,
I get the nice shadow coming on the wall however its way to strong...,
how would i doll down the shadows, refraction rollout has a check on affect shadows,
checking and unchecking this option does not make too much of a difference....
rendering method irr map and lc
any help would be appreciated...
Edited by Andrew1
spent 3 hours testing..., can not come up with a solution...
100 refractive transparent objects in real life do not cast shadows except for the edges...
whats going on with the vray material...
I excluded the object in light property from casting shadow , however the gi solution still casts brutal shadow....
anyone ?
thanks,
Andrew
this is an interior scene...
it is the gi that is causing the problem.... and there is no control to tone it down...,
I went to object vray property and turned the gi off of the object...
it looks better the brutal dark shadow is gone,
but gone completely... I do want a bit of a shadow accent there though....
I will post a shot in a few minutes
This is driving me crazy... I am usually pretty good at figuring stuff out on my own
Just wanna add that this is rendered using ir/lc method and the render below is a straight render, thisis what I get with 100% refractive material with affect shadows on....
Edited by Andrew1
Can you post a shot of how it was coming out originally? Also, is that supposed to be the color of the glass? Sort of a smokey gray? Or is that a result of turning off the GI?
One trick you can try is go to your color mapping section under the V-Ray tab and try a 0.1, 0.2, or 0.3 in the dark multiplier, That will immediately reduce the darkness of shadows......
thanks guys for all the replies.
I just resolved the problem... I had unchecked in GI Caustics refractive check mark...,
after enabling the option I got the result that I was looking for..
looks great now , I will post a pic shortly..
Edited by Andrew1
