COLNAGOBOY Posted November 1, 2012 Share Posted November 1, 2012 Does anyone know if there are any max plugins or scripts which allow distribution of the multiple objects on a terrain surface in one shot, like Sketchup's Drop script? Thanks in advance Link to comment Share on other sites More sharing options...
Tommy L Posted November 1, 2012 Share Posted November 1, 2012 Multiscatter is good, shich is a commercial plugin. Scatter object in Max is good too. Link to comment Share on other sites More sharing options...
aniketf11 Posted November 1, 2012 Share Posted November 1, 2012 Forest pro or K lite is also good...by default max have a scatter option in compound object.... Link to comment Share on other sites More sharing options...
byoungsooahn Posted November 1, 2012 Share Posted November 1, 2012 Check Glue from Itoo. http://www.itoosoft.com/freeplugins/glue.php Link to comment Share on other sites More sharing options...
Scott Schroeder Posted November 1, 2012 Share Posted November 1, 2012 +1 for Forest Pro, Forest Light can only do flat objects and limits you to only 3 objects you can scatter, which may not work well for terrain. If you don't want to spend any money, you can paint them on your terrain with advanced painter in max. You could also achieve this with a particle system. There are quite a few ways to achieve this with the tools inside max. Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted November 1, 2012 Share Posted November 1, 2012 Does anyone know if there are any max plugins or scripts which allow distribution of the multiple objects on a terrain surface in one shot, like Sketchup's Drop script? Thanks in advance If you simply want to drop objects to the ground that are already scattered/distibuted then I would use Soulburn's ObjectDropper script. Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted November 2, 2012 Share Posted November 2, 2012 If you simply want to drop objects to the ground that are already scattered/distibuted then I would use Soulburn's ObjectDropper script. Neil's website is currently offline (at least the scripting part). Link to comment Share on other sites More sharing options...
Scott Schroeder Posted November 2, 2012 Share Posted November 2, 2012 Neil's website is currently offline (at least the scripting part). Is it? This link works for me: http://www.neilblevins.com/cg_tools/soulburnscripts/soulburnscripts.htm Maybe he moved it around? But, yeah, the object dropper script is pretty fantastic as wel. Link to comment Share on other sites More sharing options...
